She overheated, again!
Old Jun 1, 2011 | 06:02 PM
ajoshi91's Avatar
ajoshi91
Default She overheated, again!
OK guys so if you can remember back around april 10th or so my 2002 4.7l durango was overheating. We changed out the t stat and topped it off with coolant.
Than again around may 10th she was overheating again and i "professionally" got the coolant flushed.
both times she stopped over heating. And now today i was out driving and she overheated, again!
At this point idk what the problem could be. she over heats, we do something it stops than 3-4 weeks later it happens again.
there has to be some bigger problem here than just air in the system mixed antifreeze's or the t stat.
Any ideas? its driving me crazy!!!
here are links to when i posted on this topic before if it helps any.
https://dodgeforum.com/forum/1st-gen...heat-high.html
https://dodgeforum.com/forum/1st-gen...ing-again.html
https://dodgeforum.com/forum/1st-gen...tifreezes.html
Old Jun 1, 2011 | 06:06 PM
modain's Avatar
modain
Not knowing anything about the other thread you mentioned: how old is your radiator? My 2001 Durango didn't overheat, but the radiator wouldn't keep it cool if it was running on anything other than flat ground. I replaced the radiator and it cools just fine regardless of load and climb.
Old Jun 1, 2011 | 06:18 PM
rob[GL]'s Avatar
rob[GL]
I was going to suggest the same thing... Check the rad!
Old Jun 1, 2011 | 08:23 PM
srch4me's Avatar
srch4me
others have sugested checking radiators for hot spots so that sounds like it could be a good idea.... give you an idea of if your radiator is bad or not...
Old Jun 1, 2011 | 08:24 PM
ajoshi91's Avatar
ajoshi91
Shes got 81,500 miles on her roughly. I don't think the radiator is bad. at least i'm hoping its not ad. i might have to go talk to a mechanic but what they always suggest is bringing it in for a diagnosis.
On a side note i opened the bleeder valve up once she was up to operating temp and there were/are plenty of bubbles seeping out. does that mean there is air in the system. the radiator cap on the top lone is closed.
guess i'm just waiting for hydra shrp or widow to jump in since they've been there on the other threads as far as the problem goes.
Old Jun 1, 2011 | 08:29 PM
srch4me's Avatar
srch4me
they will jump in here soon enough with thier wealth of knowledge... lol
Old Jun 1, 2011 | 08:34 PM
ajoshi91's Avatar
ajoshi91
yeah most likely. well for now i'm gonna try to burp the system as they explained before and i think i may have air in the system. but i wanna play it safe as if thats not it to keep looking for a problem just in case there is one. you can feel by hand the heat off the radiator right?
once shes up to temp i should be able to feel if shes hot or cold on the top or bottom?
Old Jun 1, 2011 | 08:36 PM
srch4me's Avatar
srch4me
yeah... you should be able to feel heat coming off of the radiator if i remember correctly...
Old Jun 1, 2011 | 08:40 PM
devinpitcher's Avatar
devinpitcher
There were a lot of bubbles? Sounds like a blown head gasket to me. The exhaust gases are getting in and disrupting the flow of coolant, therefor causing the overheating.
I suggest you get the head gasket checker from NAPA and verify.
Old Jun 1, 2011 | 08:41 PM
ajoshi91's Avatar
ajoshi91
what would've caused my head gasket to blow in the first place? what are causes of that? and i think there would be more signs to a blown head gasket.
