No Bus strikes again!! lol
Old Jun 16, 2012 | 12:51 AM
hydrashocker's Avatar
hydrashocker
Sounds to me like a PCM failure.
Old Jun 16, 2012 | 10:46 AM
tank99Dango's Avatar
tank99Dango
What if it was just a dry rotted wire? I had an 88 bronco II, with the 2.9. Went out to drive it to work, it would crank, crank..never fire. Turns out a power wire that goes to the fuel injectors was dry rotted, and basically fell apart in their hands. They replaced $392 dollars worth of stuff before finding a 10 cent piece of wire that fixed the problem. So, no, it may not be that simple...
Old Jun 16, 2012 | 05:50 PM
TravisN.'s Avatar
TravisN.
Also... it only happens when my wife is in it...
I'm thinking about just kicking her out and making her walk! Lol
Old Jun 16, 2012 | 10:05 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
this would be the cheapest option, lol
Old Jun 17, 2012 | 12:53 AM
jsayers73's Avatar
jsayers73
Just got a new pcm this week and the dingo has never run better. What a joy. I checked everything and replaced everything and a new pcm solve the problem.
Old Jun 17, 2012 | 01:05 AM
TravisN.'s Avatar
TravisN.
Or the most expensive option... depending on how you look at it! Lmao
Old Jun 17, 2012 | 07:20 AM
shrpshtr325
THE ULTI-MOD
i was thinking cheapest and quietest (no more nagging lol)
Old Jun 17, 2012 | 10:26 AM
tank99Dango
$1000+ for a divorce lawyer..maybe not
Old Jun 17, 2012 | 03:12 PM
hydrashocker
Nice to see you got it fixed with a new PCM.
Old Jun 17, 2012 | 09:59 PM
1999fivepointnine's Avatar
1999fivepointnine
Having had that " No Bus" problem more than once in the past I can tell you that the PCM has an internal issue, now, get a good one from a dealer or Napa, don't buy anything from ACE, (auto computer exchange). I recently had the issue, the typical problem after an " No Bus" condition is no fuel signal to the fuel pump. Listen closely when you turn the key to ignition, with everything powered up, and right before a " No bus" odometer, the fuel pump sound is missing. Common problem in PCM's and there are a couple of capacitors that go bad. Like I said, get one from Napa, or Advance, or anyone that deals with Cardone, which is the largest rebuilder source for all the above mentioned auto parts dealers aftermarket. Otherwise, get ready to pay around $800-$900 from a dealer. I paid around $400 w/exchange from Napa, and it was a Cardone rebuild. I got 6 PCM's from ACE before I learned my lesson!
