Spark Plug Replacement
Old Jun 13, 2012 | 11:18 PM
dsolorio's Avatar
dsolorio
Default Spark Plug Replacement
http://www.mediafire.com/view/?c3qc2053vqckcwl
I posted this because I noticed some people have trouble getting to the #8 Spark Plug. If you have the right tools its just as easy as the other 7 plugs. This is on the 4.7L
Old Jun 13, 2012 | 11:35 PM
master tech's Avatar
master tech
Site Moderator & Tech
I just take the 10mm nut off the oil dip stick and move it about 6 inches and the allows me to replace the number spark plug.
Old Jun 14, 2012 | 08:58 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
spark plug gap should be .040 not .045
Old Jun 14, 2012 | 09:55 PM
dsolorio's Avatar
dsolorio
I don't know what I was thinking when I did this. I don't think I've needed to gap anything at .045. Anyway, its fixed on the file. Thanks. I double checked the plugs and only ONE was at .045
Old Jun 14, 2012 | 10:15 PM
shrpshtr325
THE ULTI-MOD
archived
Old Jun 14, 2012 | 11:08 PM
dsolorio's Avatar
dsolorio
MasterTech, I don't see what you are talking about. The motor oil is far to the right and the trans oil is just to the left and neither one have a but close by. The line over the coil pack I believe is a vacuum line. Is this what you were talking about?
Uploaded with ImageShack.us
Old Jun 14, 2012 | 11:25 PM
master tech
Once the nut is off the coil pack, grab the transmission tube and pull it toward the passenger side fender. Then lift and rotate the coil and pull it out.
Old Jun 15, 2012 | 12:19 AM
dsolorio's Avatar
dsolorio
Oh I see, its the nut and the plug itself that can be somewhat difficult. Not so much pulling out the coil pack. That's what I was getting at.
Old Apr 28, 2013 | 10:47 AM
dsolorio's Avatar
dsolorio
