TURN SIGNALS DO NOT WORK HELP!!!!!!!!!!!!
Old Aug 20, 2005 | 04:50 AM
budman5555's Avatar
budman5555
Default TURN SIGNALS DO NOT WORK HELP!!!!!!!!!!!!
Please help guys!!! For a while my turn signals would turn on then after a few flashes go out while sitting at a stop light. Then they would only work every now and then. Now they have quit all together. I have tried to replace the combo turn switch on the steering column. That did nothing (now I have one for sale $50 plus shipping). I checked all the fuses and replaced the one or two that was bad, but that still did not fix my problem. I got underneath trace all the wires from front to back to the box under the hood, all ground wires look good. Stuck my head up under the dash check all the connections they look good. Thought about the flasher but all the other lights work fine my hazards work. When I pulled the flasher out(green box) my hazards go out. So if the flasher works the hazards then it should work the turn signals? The flasher wouldn't be half good would it?? My Durango is a 1999, 4x4. Thanks Matt Please Help
Old Aug 20, 2005 | 04:51 AM
budman5555's Avatar
budman5555
Default RE: TURN SIGNALS DO NOT WORK HELP!!!!!!!!!!!!
I have took it to a repair shop and they told me to try the flasher. So I took it to the Dodge dealership, and he said there was only one flasher listed. So I went and pulled mine out and it killed the flasher. So I told him that was not it, because why would part of a flasher work and not the other part, and plus woudn't a flasher just die and not keep coming back again and again and then die????
Old Aug 25, 2005 | 01:05 PM
Digitoxin's Avatar
Digitoxin
As the flasher heats up it may cause the circuit inside to
open. Then it may or may not contact again . Tap on it while
you have the turn signal on and see if it act up.
https://dodgeforum.com/albumphoto.as...Type=6&apage=7
Old Sep 11, 2005 | 11:17 AM
landsteam's Avatar
landsteam
I also have the same problem. Any idea's on what went wrong?
Old Sep 11, 2005 | 05:27 PM
budman5555's Avatar
budman5555
Do you guys have a aftermarket security system on your vehicle. That ended up being my problem. The after market system was grounding out my flasher. So I had the system removed and bought a new flasher. Now everything is GREAT!!!! Matt
Old Sep 16, 2005 | 08:11 AM
M Shark's Avatar
M Shark
I have noticed a somewhat similar problem. When I signal I have seen that my hazards have turned on. This has happened to me maybe 4 times during the past month I've had my truck.
Old Mar 25, 2006 | 01:31 AM
grayhorse93's Avatar
grayhorse93
Did you ever find the problem ?
My 99 Durango is doing the same thing!!
Old Mar 29, 2006 | 12:59 PM
Biggrich76's Avatar
Biggrich76
I had a similar problem in my 99 Durango. The problem stemmed from a short in the hitch wiring. Sometimes, if the wiring or connectors get corroded, they can cause shorts in the signal/hazard lights. I just pulled the taillights off and disconnected the hitch wiring (since I don't use the hitch anyway) and it solved my problem. Hope this helps.
Old Mar 29, 2006 | 08:55 PM
acy's Avatar
acy
Hi im having the same problem the dealer wants to charge me ariund 200.00 to fix what did you do to fix it. please let me know need help.
Old Mar 29, 2006 | 09:00 PM
acy's Avatar
acy
I have a 2000 dodge durango having problems with signal lights they do not blink only a tick sound but thats all and only once it they were working and suddenly just stopped and sometimes they will come back for about 2-3 flashes and they stop. now there is nothing. Checked the flasher hazzards work. Please help
