Tie rods?
Old Jun 26, 2012 | 12:41 AM
otgarzā's Avatar
otgarzā
Default Tie rods?
Lifted my truck up this week to do a check on the suspension and steering and i found that my passenger side tie rod moves up and down. Aside from that the driver and passenger side tie rods can be rotated by hand. Are they supposed to rotate or is there a deeper problem? The passenger side is busted for sure though.
Old Jun 26, 2012 | 05:12 PM
tank99Dango's Avatar
tank99Dango
Since that is all part of the rack and pinion, its more than likely the whole rack may need to be replaced. That doesn't sound safe to have it on the road...
Old Jun 26, 2012 | 06:22 PM
topdogcustoms's Avatar
topdogcustoms
sounds like you need new tie rod ends there $18 dollars for duralast at autozone
Old Jun 26, 2012 | 10:06 PM
tank99Dango
yeah, but if they are wollered out, because he said he had up and down play in the inners...that would mean busted rack ends...would it not?
Old Jun 27, 2012 | 03:06 AM
otgarzā's Avatar
otgarzā
I meant that the outers move up and down. Both the inners and outers just rotate or swivel.
Old Jun 27, 2012 | 12:11 PM
Dirtrango's Avatar
Dirtrango
Rotating means the set nut isn't tight to the end of the rod causing it to turn. I just did mine due to having the same issue you have. Just do the tie rods inner and outer on both sides better safe then sorry.
Old Aug 5, 2012 | 01:30 AM
otgarzā's Avatar
otgarzā
just did the outers two weeks ago lookin to do the inners soon and be done with the durango until schools out again in december
Old Dec 17, 2012 | 10:46 PM
otgarzā's Avatar
otgarzā
Eventually did both inners and outters. It was straight forward and it made the steering just a bit tighter like it should be thanks again guys.
