Best positon to put it in
Old Jul 2, 2012 | 03:28 PM
TurboStixx's Avatar
TurboStixx
Default Best positon to put it in
So I am having a debate with a few friends, just a friendly debate. I am Running my 99 D, others are Running a 2.5L Jeep Wrangler, and a Chevy Vortec Crap (actually is a decent motor).
The question is, which is better to run in the sand with? We are talking soft sand, Now none of us have gotten stuck in any position, but we are wondering which is easier on the Transmission. I run in 4-Part Time (or Full time) which ever is for Soft and Hard ground..or 4lo..Which is easier on the tranny?
Old Jul 2, 2012 | 04:05 PM
srch4me's Avatar
srch4me
I would think 4 hi because its for higher speeds. Sand is about speed not low end torque if I recall. Someone feel free to correct me if I'm wrong though
Old Jul 2, 2012 | 04:24 PM
TurboStixx's Avatar
TurboStixx
Speed limit is 15mph...So no need for speed lol, I use 4Lo when I pull someone out, which btw did happen lol Pulled a Ford Excursion out
Old Jul 2, 2012 | 04:45 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you should be using 4wd part time (this should NOT be used on hard surfaces) as this will give you more traction, none of them will strain the trans because sand gives so easily that driveline bind (the cause of the mentioned strain) wont be able to build up.
Old Jul 2, 2012 | 04:49 PM
srch4me's Avatar
srch4me
Yeah I'd only use 4 lo for puling people out
Old Jul 2, 2012 | 08:39 PM
adukart's Avatar
adukart
Yeah 4hi for sand. I have used 4lo in deep snow, deep mud (not racing the tires), pulling out fords and chevys (havent had to pull a dodge yet, hmmm), and climbing steep grades off-road for extended periods of time.
Old Jul 3, 2012 | 06:20 AM
lvphotos's Avatar
lvphotos
2wd in 90% desert works. 4hi in sandbowl in Parker,AZ worked well. Yanking Chevy diesel out of sand truck kind kicked out of 4lo. Computer said no too much tourqe. Low for rocks and down hill speed. I run 35" bfg at and they handle all but nasty mud.
Old Jul 4, 2012 | 12:17 AM
master tech's Avatar
master tech
Site Moderator & Tech
I agree with sharp using 4 wheel drive part time. And when pulling someone out, then use 4 low.
Old Jul 4, 2012 | 11:29 PM
krupaeric's Avatar
krupaeric
ok i got a question to add to this thread if you dont mind? my d is a 98 and for all i know so far my truck is either in 4 wheel or its not. i dont beleive i have part time. heck i dont even have a light that turns on when i engage the 4 wheel. and i got a lever for the 4 wheel not a turn *** or push button.
so my question is if my light doesnt turn on showing that my 4 wheel is engaged. does that mean somethings wrong with it?
or because my d is a 1st gen 1st year model do i not have part time 4 wheel so my light wouldnt even turn on?
or am i just dumb and not doing something right? even though i know my 4 wheel works cuz i have used it alot?
or is 4high actuially part time and i just dont have a light that turns on?
Old Jul 5, 2012 | 02:06 AM
srch4me's Avatar
srch4me
It should be a level to go to 4 hi 2 hi neutral our 4 low. Check the dash light. It might be burnt out. To check if 4x4 is engaged go to a gravel lot put it in 4 hi and crank the wheel and do a circle. You should feel it buck a bit trying to turn
