my d is acin wierd
Old Jul 20, 2012 | 09:58 PM
acfd813nick's Avatar
acfd813nick
Smile my d is acin wierd
hey guys i have a 2002 durango sxt 4.7. i just got the ac charged and it works great but when i have it on and i am drivin my d acts like it has an engine brake as soon as i let off the gas. idk what is goin with it never seen another vehicle do this before. i can be drivin down the interstate and when i let off the gas my rpms jump up and it feels like my trans downshifts is this normal and somethin i just gotta get used to or is somethin messed up.
thanks in advancesss
Old Jul 20, 2012 | 11:57 PM
topdogcustoms's Avatar
topdogcustoms
i would check the fan clutch it sounds like its locked up
Old Jul 21, 2012 | 12:52 AM
that_guy's Avatar
that_guy
yeah the extra heat from the a/c condenser could be exaggerating the effect of a bad fan clutch. Check to see if your electric fan is working; if it's not working it could be causing an extra load on the mechanical fan and causing it to be engaged more than it needs to be.
Old Jul 21, 2012 | 08:39 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
sounds to me like the trans is downshifting for some reason, i would get in touch with master tech and see what he thinks, he is the local transmission expert.
Old Jul 22, 2012 | 02:00 PM
master tech's Avatar
master tech
Site Moderator & Tech
Were you having this problem before the A/C service? There are a few reason for the transmission to come out of lock up, 1 letting your foot off the gas and the RPM will come up, 2 the brake light switch will do the same thing and will cause the transmission to down shift. The most common problem has been the TPS, Buy Mopar not aftermarket. If the temp is raising to a point to overheat, the transmission will down shift and fan clutch should give you a loud sound from the front of the engine. And i would also check the ground wires on each side of the engine block too.
Old Jul 22, 2012 | 03:05 PM
acfd813nick
thank you i was not having this issue before also the sound isnt coming from my fan i know my engine is reved cause my rpm guage goes up and i have loud exhaust so i can hear that as well. i changed th tps when i bought it less than a year ago but got it from autozone should i replace it with one from the dealer anyway or is that ok thanks for all yalls help
Old Jul 22, 2012 | 03:06 PM
acfd813nick
u can also feel the truck kickdown
Old Jul 23, 2012 | 04:20 PM
master tech
I would buy a Mopar sensor. I have had too many problems with aftermarket sensors.
