high rpms after replacing radiator
Old Jul 29, 2012 | 08:46 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
definitely sounds like it could be the new clutch needing to break in
also double check your owners manual, but your truck should have ATF+4 in the trans which is a 100k mile fluid, no need to change it out at 30k if there is nothing wrong
Old Jul 31, 2012 | 08:21 PM
Magoo's Avatar
Magoo
Previous shop thinks a heavy duty clutch fan was installed and is making the engine as loud as it is. Without even seeing or hearing the truck they described the sound exactly - a raging fan.
I'll hold off on the trans fluid swap as even though I go off road its not enough to hop on the Schedule B fluid interval if not needed and I know they new about the ATF+4.
Thanks for the help!
Old Aug 2, 2012 | 02:16 AM
topdogcustoms's Avatar
topdogcustoms
at first i got the autozone fan clutch then returned it it it would stay on all the time i ended up getting a mopar and it works like a champ thank god for hookups at dodge
