high rpms after replacing radiator
I just to radiator go, so I ended up replacing the radiator, fan clutch, thermostat and housing, and upper and lower hoses.
The engine seems to be slow on shifts and is noticable louder as the engine sounds like the rpms are really high.
Does the PCM or something else need to recogize the new equipment/performance? When i first got it back the engine reved high on start-up and shifted into gear hard. That seems to be better, but the engine still sounds like its screaming as I drive.
For what you have replaced will not have anything to do with the PMC box that I would know of cause there is no elc hookups for em,, But if you put a new clutch fan on it then that could be the diff an mite have to get use to it,, But I don't think any of this will have anything to do whith the way it shifting,,
I called the shop on the fan clutch - they didn't seem to think that would be the case or that there were options.
One point they brought up was maybe some trans fluid was loss while the lines were removed. I'm going to check the level while I'm out and about today.
Trans fluid temp full when at temp as far as I can tell.
I guess I should inlude a bit of history to show a timeline in case something pops up to anyone reading this:
- Jun-09, 107K, replace thermostat and fluid
- Nov-09, 109K, shop rebuilt radiator w/plastic side tanks.
- Apr-11, 120K, replaced drive belt. Shop recommended belt tensioner and fan clutch - no money, so didn't do.
- Jul-12, 132K, noticed upper hose leaking. I replaced hose on Saturday, added fluid in hose but didn't open vent nut to purge air.
- Drove over weekend no problems - radiator split at plastic tank 5 minutes in drive to work early Monday morning.
- Shop installed new radiator - aluminum with plastic tank, fan clutch, thermostat and housing, lower radiator hose.
- Got truck back, seems to start up with high rpms, shift into gear a little hard, and sounds louder with higher rpms and delayed up-shifts while driving.
- Checked trans fluid but seems to be full.
What was wrong with the radiator to begin with? It's possible that the bad radiator could have caused the coolant to mixed with the trans fluid, depending on where the radiator was damaged. Make sure there's no coolant in your trans. Also, does your heat work properly and does the vehicle warm up to operating temp properly? Could have air in the system due to them not bleeding it correctly.
The thermostat was replaced in 2009 after cooling system started to leak (don't remember where) and overheat in a summertime off-road trip. There wasn't a breakage a couple months later to make me fix the radiator, I think I was just trying to pay attention to make sure there wasn't any leaks and must have noticed the radiator leak.
Regarding Transmisson repairs:
From what I can tell I would say truck gets up to temp in time - guage at half way in 15 miles.
- Jul-07, 86k, trans fluild replaced
- Dec-07, 91K, new transmission oil pressure switch, speed sensor switch, new fluid.
- Oct-08, 99K, new line pressure sensor and shift shaft seal, fluid.
Trending Topics
Took truck back to shop to check on everyone's suggestions - here's what the responses were:
The only thing I can think is that the fan clutch was always bad or I'm hearing a fan run now more than it was before. The rpms don't seem to be high and shifting is good - maybe I'll bring it to a trans shop to get their opinion and replace fluid since its been 30k.
One thing that for sure is better - A/C now works when I'm stopped at a light or parked. My wife hated it when the cold air stopped when I stopped, and the new fan clutch may be providing more air flow/torque which is helping the A/C.
- no mix of coolant/anti-freeze
- didn't see a vac line not connected and mentioned that truck "wasn't hesitating"
- trans fluid level good
- coolant sensor good and there wasn't any code sent
