4.7 Electronic Nightmare!
Old Aug 19, 2012 | 07:29 PM
battsman53's Avatar
battsman53
Default 4.7 Electronic Nightmare!
My 2003 Durango has 175,000 miles on it, but it runs and drives great when it's running. It all started with check engine light. So I started running check's with ODB II and it showed multiple fault codes. So I started replacing sensors associated with each code and clearing the PCM each time. Sometimes the vehicle would drive okay but after a while the check light would come back on with different fault code. I even replace battery because voltage was a little low. It will start on first try but once it get warm it will shut down and will not restart until it cools down. Finally I started running checks of voltage at each sensors and it had no voltage at Camshaft and MAP sensors. According to manual in states it is a PCM problem. I was wondering if anyone else has had these problems before I replace the PCM.
Old Aug 20, 2012 | 05:29 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
it does sound like a PCM overheating problem, next time it happens put a bag of ice on the PCM and give it a couple minutes to cool off, try starting it, if it starts this way the PCM is overheating, it is a common issue on 98-00 MY trucks, but does happen on a few of the newer ones too once in a while.
