clockspring
Old Aug 21, 2012 | 07:51 PM
srch4me's Avatar
srch4me
Default clockspring
What's the best way to recenter the clock spring?
Posted from Dodgeforum.com App for Android
Old Aug 22, 2012 | 10:13 AM
Sooper's Avatar
Sooper
Questions:
Are you referring to the air bag clock spring?
Why are you even messing with it? Did something happen and you're replacing it?
Old Aug 22, 2012 | 01:23 PM
MoparMan1991's Avatar
MoparMan1991
Well I'd count how many times it can turn total and then cut the number in half. Don't get carried away and overturn, obviously you don't want to break it. Your clockspring should have a little locking tab on it to stop it from turning, just push it in and twist.
Old Aug 22, 2012 | 04:44 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
center the steering wheel before removing it
Old Aug 22, 2012 | 05:15 PM
MoparMan1991
To me, it sounded as if his colckspring was generally not centered. If this is the case, then centering the steering wheel would do nothing. I suppose he should be a little more detailed with his question.
Old Aug 22, 2012 | 06:46 PM
shrpshtr325
THE ULTI-MOD
the procedure for removing the clockspring calls for centering it so that it is in the correct position.
Old Aug 22, 2012 | 06:49 PM
MoparMan1991
He never specified if the clockspring was installed and needed to be re-centered in the wheel, or if he has a different clockspring that needs centered before install, are you picking up what I'm putting down?
Old Aug 22, 2012 | 07:19 PM
shrpshtr325
THE ULTI-MOD
i understand exactly what you are saying, however the only way that the clock spring could be not centered is if it was removed without following proper procedure, do you understand this basic piece of information??
while installed the clockspring cannot move without the steering wheel turning (unless something breaks), and if PROPERLY removed it is fixed in the centered position(there is a centering PIN in it), you seem to be the one who is not understanding what is being said. and that will be the end of us throwing the thread off topic
Old Aug 22, 2012 | 07:32 PM
MoparMan1991
Right. But he never said it was installed, you're simply implying that it is.
Old Aug 22, 2012 | 08:45 PM
srch4me's Avatar
srch4me
Ok. Here let me clarify. I forgot to Lock the steering wheel in the middle before pulling the gearbox so I've no idea if my steering is centered right or not. I wanted to know if I can pull the clockspring and center it manually then reinstall it.
