how to lift a junkyard D?
I've Ben pondering this for some time, I know I need a new exhaust and I can get one cheap but its in the junkyard sitting under a Durango that has no wheels and sits directly on the ground. How would you suggest I safely lift it enough to remove the exhaust without being crushed? And would it even be useable while on the subject would the exhaust from an R/T fit a 5.2?
Originally Posted by Old_School
Why would you waste your time with a junkyard exhaust system??
Yes i understand it is a cheaper option but, it will end up costing you more in the long run. You would be much better off putting up the money for a new system and doing right the first time.
Posted from Dodgeforum.com App for Android
Trending Topics
Some people have more brains than ambition, others have more ambition then brains....
Yes i know that people fall on hard times and sometimes the money just isn't there.... trust be i been there.... My point is or was that buying a junkyard exhaust system that has been used and is on a vehicle that is laying on the ground is a bad idea. as sharps pointed out...
For the money you spend on getting the system from the yard and the money you would spend to fix it you would be better off either fixing up what you have or replacing with new even if it is pieced together with cheap universal parts. Then you can save up and get what you like when you have the money together
