Suitable Electric Fan to replace Clutch Fan
Old Mar 21, 2013 | 02:37 PM
  #91
jsnm's Avatar
jsnm
Sounds good,thanks
Old Mar 21, 2013 | 05:36 PM
  #92
lvphotos's Avatar
lvphotos
For the Black Magic Fan and controler.
Old Mar 21, 2013 | 08:49 PM
  #93
that_guy's Avatar
that_guy
Here's another wiring diagram that's more general compared to the one above.
If the fan is dual speed (2 different hot wires) and the controller supports it you just have another feed from the controller activating another relay that powers the other speed.
BTW, I can highly recommend the dakota digital pac 2700 controller. I've been running it for nearly a year with no issues at all.
Old Mar 22, 2013 | 07:39 AM
  #94
jsnm's Avatar
jsnm
Nice! Thanks for the diagrams guys,I have everything on order,hoping to get this project tackled next weekend.I'll post up pics of it when I get done.
Old Mar 22, 2013 | 09:44 AM
  #95
that_guy's Avatar
that_guy
What controller did you go with?
Old Mar 28, 2013 | 08:01 AM
  #96
jsnm's Avatar
jsnm
I bought a complete kit from FF Dynamics,its the electric fan with aluminum shroud,installation kit,and wiring.Just got it in this morning,looks like a well put together kit.The controller,relay etc are all waterproof sealed,has the option for a temp probe or screw-in style sensor.
Might get started on this after work tonight and see how it goes.Here is a pic of the wiring:
Where did you guys tap into 12V ignition power under the hood for your setups?
Attached Thumbnails Suitable Electric Fan to replace Clutch Fan-img2077e.jpg
Old Mar 28, 2013 | 08:59 AM
  #97
that_guy's Avatar
that_guy
you should be able to find constant, ignition on, engine running, and a/c feeds all from various relays in the relay box. I don't remember which ones I got power from off the top of my head. I believe I got engine running and a/c on from the a/c relay, and constant 12v from the fog light relay. I did get a few of the feeds from inside the cab since my controller mounts inside.
Old Mar 28, 2013 | 09:50 AM
  #98
jsnm's Avatar
jsnm
nice,im going to check it all over tonight.thanks again
Old Mar 29, 2013 | 07:47 AM
  #99
jsnm's Avatar
jsnm
Well,got it all hooked up,night and day difference driving the truck,I think anyway,definitely less drag on the engine,and a lot quieter.
Going to clean up the wiring a little better when I get time,was beat last night doing this after working all day,didn't feel like it.
And I hooked up an led so I know when it's running:
Thanks for the pics of the relay wiring that guy,definitely a huge help when running the a/c clutch wiring and ignition switch.
Old Mar 29, 2013 | 04:20 PM
  #100
that_guy's Avatar
that_guy
Looks good!
