Clicking noise when backing up
Old Sep 6, 2012 | 09:36 PM
raleigh5's Avatar
raleigh5
Default Clicking noise when backing up
1998 Durango 5.9L SLT.
there's a very noticeable clicking that comes from the rear of the Durango when i am backing it up. it sound like an amplified cricket. i thought at first it might be the drum brakes adjusting( i'm new owner of this ). but i am guessing that is not the cause. i do believe that the same sound ocasionally comes from the front of the vehicle. any suggestions on what i might want to look at first to find the source of the noise? thanks.
Old Sep 6, 2012 | 09:44 PM
srch4me's Avatar
srch4me
Check the U joints
Posted from Dodgeforum.com App for Android
Old Sep 7, 2012 | 11:20 PM
cummingetit's Avatar
cummingetit
I agree with srch
Old Sep 8, 2012 | 10:55 AM
raleigh5's Avatar
raleigh5
thanks. i will check those U joints this weekend.
Old Sep 15, 2012 | 02:00 PM
raleigh5's Avatar
raleigh5
i got under the durango and checked for freeplay in the u-joints. no noticeable freeplay in any direction. had it in Nuetral when i did the check by grasping the ds and looking for movement. is there anything else that i should have done to determine the condition? or is there any other componet(s) i should check out? failed to mention that the Durango has the rancho suspension lift kit installed.
Old Sep 16, 2012 | 04:09 PM
cummingetit
You could try lifting the rear off of the ground and listening as you spin your driveshaft. Possibly a chipped ring or pinion tooth? This is going to sound stupid but i had a Trans am once with a super annoying ticking noise. I finally jacked it up and put it in drive because i couldn't pin it down. Turned out to be one of those thick zip ties someone put on the bottom of a cross member ticking off of my d shaft
Old Sep 16, 2012 | 04:10 PM
cummingetit
Old Sep 17, 2012 | 07:26 PM
raleigh5's Avatar
raleigh5
thank you for the replies. i got the rear end up on stands to start spinning the wheels. but i noticed the rear shocks had noticeable play in them at their bottom mount point. tightened those up and also tightened the 1 'loose' one in the front. i am not getting the click sound anymore. but as it only happened periodically, it will take a few days before i am convinced that was the source of the noise. the shocks are Rancho shocks and all are mounted at their bottom with bolts and nuts. each also has a large washer pushed to the bolt head. something doesn't seem quite correct about this. but i will keep an eye on it in the future.
