Another Stalling/Won't start/ No Bus.. Help..
Old Oct 15, 2012 | 08:46 AM
one big mess's Avatar
one big mess
Master Tech I can start and drive mine for a while before everything on my dash stops working (all gauges stop working) then I get no bus will appear where the odometer is. After about ten min it will start back up. It happened to me as I was pulling into the garage. They put it on the machine and found no codes. Once we shut the key off it didn't read no bus. Since then I found out how to find the codes on my own. Still not throwing any codes. Not sure what sensors you said about disconnecting. Could you shoot me a line explaining what/which sensors. Thanks
Old Oct 15, 2012 | 05:48 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Originally Posted by Thinkster
Nope, nothing under the big plastic cover labeled "Auto Shutdown" maybe this particular year (2002) and model (Hemi RT) they failed to label stuff properly? or moved it somewhere else? Also, what's wrong with opening the PCM? I'm experienced with electronics and am aware that the circuit board is potted (encased in epoxy or some resin), but just opening it can't crack the circuit board can it? I've read you can look for bubbling in the potting that may indicate a component has fried.
2002 MY trucks only had the 4.7 or the 5.9 available, the hemi is the 5.7 and was not available, also the way that the PCM is designed if you open the case you will damage the board or the traces not worth the risk IMO, if you are replacing it and want to open it to confirm that is fine, but once you open it there is a 90% chance you will have to replace the board. (this is based on reports from other users not personal experience)
Old Oct 15, 2012 | 11:52 PM
master tech's Avatar
master tech
Site Moderator & Tech
The Bus circuit use's a +2.5 and -2.5 volts for communcations, anytime the voltage changes above 3.0 volts you will start to see the no bus message. There are many ways of loosing the bus circuit. The most common has been a crank sensor. But the PCM,radio,overhead console, heater control head, CTM, or any sensors thats on the circuit. I have also seen pins pushed out of the PCM connector cause a no bus message. I would also remove the kick panels on both side in the front and check the ground wires. That could also cause some problems too.
Old Oct 26, 2012 | 08:14 PM
one big mess
Ok so I did as Master Tech said and when the no bus showed up I started disconnecting sensors. When I got to the crank (which I already replaced) the odometer came back on and my D started right back up.
Posted from Dodgeforum.com App for Android
Old Oct 26, 2012 | 08:54 PM
shrpshtr325
THE ULTI-MOD
well, it looks like you found the culprit, while uncommon getting a bad sensor out of the box is very possible
Old Oct 27, 2012 | 04:11 PM
one big mess
I didn't take anything out of the fuse or relay boxes. I started disconnecting wires under the hood. Id do one look at the dash put and it back together untill the no buse went away (I got lucky 2nd one).
Old Oct 27, 2012 | 04:42 PM
Kensai's Avatar
Kensai
I am having sensor issues on my Durango also. Seems that the PCM will not throw a code unless the sensor is completely dead. If it is partially working, it will not throw a code.
Old Aug 13, 2013 | 03:21 AM
Thinkster's Avatar
Thinkster
Guess I haven't checked on here in a while. Well since the initial problem, I obtained the service manual and looked at the electrical schematics for the sensors that feed into the PCM. I checked voltage on the TPS, Crank Shaft and Cam Shaft position sensors as well as the relays and all seemed to be o.k. Everything started pointing more and more toward the computer (PCM) so ordered a refurb, installed it and the Durango fired up! So back in business. Kinda disappointing that the computer gave out after only 60K miles on the vehicle!
