srch4me is back in the seat
My baby is back up and running now. I only have one issue. The gearbox was rebuilt by rockauto but the steering is still loose. Is that just normal or should it be pretty tight?
Posted from Dodgeforum.com App for Android
Rebuilt as in reman?
Loose is a small description, have someone watch the box for you when turning to see if the play is in the joints, but if their tight and theirs slop in the wheel it may be a bad box. Sometimes the feeling of a new box is awkward too, 100% diff from a warn.
Yes. I remaned.. It was supposed to come back like new. The slop is in the box. It's tight in turns but going straight down the road you Continually have to move the wheel back and forth. It just seems like the fact that when I turn the steering wheel the shaft that goes into the box turns a bit before the tires do
Put a friend under the Durango and have him watch the box's input and output shaft. First, compare when the input moves to the output. If there is a delay in response then yes the box might need to go back. If there is no delay, check output shaft movement vs wheel movement. Typically a suspension component fails and it's hard to detect visually unless you're very specifically looking for it and someone else watching for you can help greatly.
Maybe its not the box and just the installer
J/k, how was it bleeding?
Trending Topics
I'm interested about tightening the box too. My steering is just like you said yours is (albeit with the original box), a bit sloppy in a straight line, but tight while turning
There is an adjustment nut on top of the steering box, it has a lock nut on top of it. I don't remember the size but its around that 10-14mm size iirc. Doing this helps take up the slack you may be feeling in the steering wheel. Only do about 1/2 a turn at first, clockwise like you are torquing down a bolt, and go from there. If you tighten it to much your steering will feel quite heavy. Remember this is for the older D's with steering boxes and not rack&pinion like the 01-03.
I just tightened mine a some. On mine the lock nut was 16mm (about 5/8in) and the inner shaft was a Torx-30. I tightened it a little over 1 whole turn with a bit driver (didn't really feel any resistance). It definitely feels tighter now, only about half as much play as there was before. I didn't tighten it any more because I wasn't sure if it would be ok to go further? Is it alright to tighten it more I should I just leave it alone?
