Question about shocks
I'm fairly certain I need new shocks; front end bounces after bumps and back end can get a little squirrely in corners. Ride is generally kinda rough, and I don't really do any off-roading.
I am also getting a LOT of squeaking/creaking from the front end over any/every bump. Would replacing the shocks also fix this? Do bushings come with new shocks?
It may be that there are other bushings that need attention I guess, but if I can fix the annoying squeak by just replacing the shocks then all the better.
2002 R/T
Thanks in advance.
2002 R/T
Thanks in advance.
2002 R/T
Thanks in advance.
2002 R/T
Thanks in advance.
Posted from Dodgeforum.com App for Android
If you're getting lots of bouncing from the front end, I'd look into new shocks. Don't go cheap though. I learned that lesson the hard way when I bought some cheapo Monroe's. Replaced them after 1-1/2 years with Bilstein's - which are absolutely fantastic! Check Tirerack.com
