a/c compressor knock?
Old 10-04-2012, 01:25 PM
Duralude09's Avatar
Duralude09
Duralude09 is offline
Question a/c compressor knock?
so please please please tell me that a knocking compressor means its about to explode.
Driving home today i began to hear loud knocking about a block away from my home i pull into driveway and its still there. i turn a/c off so i can hear better and the knock goes away. turn it abck on. knock comes back. i open the hood turn the a.c on and the knock continues and i can feel the knocks if i touch the compressor. does this mean its saying good bye?
Old 10-04-2012, 09:18 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
yea id say it means the co mpressor is shot, but why do you want the a/c compressor to be bad??
Old 10-04-2012, 10:12 PM
Duralude09's Avatar
Duralude09
meant to say. not about to explode. im tight on money and dont have funds to deal with a broken a/c compressor. would a low freon level make it knock?
Old 10-05-2012, 07:55 PM
shrpshtr325
THE ULTI-MOD
no not directly, however the compressor is lubricated by oil in the freon which being low will cause noises.
which engine do you have? if you have a 5.2 or 5.9 you can buy a shorter serpentine belt and bypass the a/c compressor until you can get it fixed (or not as you decide)
Old 10-05-2012, 11:52 PM
Duralude09's Avatar
Duralude09
i have the 4.7 with 235k on it
Old 10-06-2012, 08:23 AM
shrpshtr325
THE ULTI-MOD
in that case you could buy a dummy pully to put on in place of the compressor, im not sure how much they cost but a whole lot less than a new compressor.
or, since in the origional post it sounds like it only does it when the a/c compressor is running, just unplug the clutch from the wire harness so that it cant engage.
Quick Reply: a/c compressor knock?
