What is this (Now Made With Pictures!)
So the girlfriend has had a 2000 5.9l Durango for about a year now. Currently, her brakes are going almost to the floor, but thats a different story. While poking around I noted some connectors not connected and a mysterious "light" thing. If you guys could tell me whats going on, that'd be awesome.
#1 Theres supposed to be a connector here, right?
#2 No idea...
#3 Light looking thing with the wires cut
#4 Something should be connected to this grey connector (on the left)
#5 Another missing connector
So in total, there are three connectors with nothing connected to them, a funky light looking thing with the wires going to it cut & a missing connector on the brake master cylinder...?
#2 No idea...
Now to figure out what those connectors are for. Her alarm works so It cant be for the alarm system...
the siren looks like the same one mine has. It's for the Mopar EVS II Plus alarm system that was a dealer option.
The connector on the side of the brake fluid reservoir is for the fluid level sensor IIRC. Not sure what all those plugs go to, but they look like they have something to do with the abs system.
The connector on the side of the brake fluid level is for the fluid level sensor IIRC. Not sure what all those plugs go to, but they look like they have something to do with the abs system.
The brakes are going south - the pedal is going almost all the way to the floor, I wonder if that has anything to do with the missing connectors. I doubt it though, I think it just needs new brakes.
Trending Topics
the plug in #1 is supposed to be connected to the wire in #4 it looks like (its a brake fluid level sensor)
the audible siren (as described above) could also be a PA speaker for a CB
one of the other two plugs kind of looks like it could be for the ABS module, but if that was the case the ABS and/or brake lights in the dash would be on.
Also, no ABS or brake lights are on the dash
Just took a look at my D. The connector in pic 4 looks exactly like the front wheel ABS sensor connector on mine. Look at the ABS ECU and see if there is another connector. I see the main connector in pic 2 is connected. However, there may be a second connector for the front wheel inputs. That could be the connector shown in pic 2 or 5. When the brake pedal goes way down, does the brake light come on? It should because of the switch in the proportioning valve. If not, someone may have previously disabled the ABS and pulled the bulbs or otherwise disabled the lighting indicators.
