Repair and Mod Oppty 5.9
Old Oct 4, 2012 | 04:16 PM
hi_speed_tourist's Avatar
hi_speed_tourist
Default Repair and Mod Oppty 5.9
Thanks for any help.
Current Sitch: Bone stock '03 5.9, 120k, plenum leak, valve cover leak, runs well but sluggish and low RPM miss.
Since its getting opened up to fix the plenum leak I (think) Ive decided on the following mods or replacements based what all you generous contributors have said:
M1 intake, 52mm tb, injector service/replace, plugs R&R, water pump, oil pump, timing chain and gear, and serp belt. ...Headers, Roller Rockers and hi-flow cats are planned in the near future.
My questions:
1. Have I selected choices that make sense: work well together, add adequate performance / dependability for the buck? Should I just stay with the Kegger?
2. Do you have a better combo for a 5.9 used primarily as a tow rig for 4800 lb. boat in wonderfully mountainous Oregon & Washington?
Admittedly I'm not the best wrench but Im not scared! dangerous combo.
Jeff Spicoli: "Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it."
Thanks again
Last edited by hi_speed_tourist; Oct 4, 2012 at 04:19 PM. Reason: answered one of my own Q's
Old Oct 4, 2012 | 09:23 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
unless the injectors are leaking or sticking dont waste your money touching them, they tend to last very well
dont waste your money on a high flow cat, the truck already has on it (they came with one from dodge)
timing chain is a lifetime part, should not need to be replaced until you rebuild the engine, if you want to replace it no harm done, just giving you a heads up.
otherwise i dont see any problems with your plan
Old Oct 5, 2012 | 01:04 PM
adukart's Avatar
adukart
Gearing If you have 3.55's switch to 4.10 or 3.92. I know its not relevant to opening the motor up. If I was you I would have the heads off at this time and do the 1.7 rockers and have the heads ported & shaved. Let it breath with that new M1 and have a custom tune done to compliment it all.
Old Oct 5, 2012 | 06:14 PM
hi_speed_tourist
I'm sure you know the feeling... got it all in my online shopping cart ready to hit SEND on a large purchase. Need some kind sign or shove to seal the deal. So..Thanks so much for the quick responses!
I had read somewhere that the timing chain can get stretched and become a bit sloppy. Anyway thanks for the advice there Shrp!
Aducart, Yes I do have 3.55 with the 46RE and plan to go to at least 3.92. Do you wish you had 4.11? How much weight are you towing?
I hear ya on the ratio rockers and until you mentioned it I had convinced myself to leave the stock heads as is. But was really leaning toward shorty headers and had researched some shaved head options: The pic is what I got when I googled shaved heads. So how much did you shave them and what was the result on your compression? Octane?
Old Oct 8, 2012 | 11:53 PM
adukart's Avatar
adukart
I have 3.92's and it is a good setup for general towing off-road use. I have towed from 1200-8500lbs. If I was (and plan on doing in the future) switching gears I would do 4.56's cause I plan on going with larger tires in the future.
