Quick Disconnect tool for 2000 durango transmission fluid coolant line
Old Oct 14, 2012 | 11:31 AM
rehayes's Avatar
rehayes
Default Quick Disconnect tool for 2000 durango transmission fluid coolant line
Does anyone know what quick disconnect tool to use to remove the transmission fluid coolant lines on a 2000 durango?
Old Oct 14, 2012 | 03:31 PM
cummingetit's Avatar
cummingetit
I bought a kit that came with all makes and models. They were made of plastic and worked "ok" for one our two uses. Would not recommend these. Id buy the metal ones next time. As for the actual size tool idk. The line on mine is 3/8. Idk if the tool size is directly proportionate to the line size or the coupler size. But at least you have an idea, and a suggestion.
Posted from Dodgeforum.com App for Android
Old Oct 14, 2012 | 11:41 PM
master tech's Avatar
master tech
Site Moderator & Tech
I use a miller tool 9546, You maybe able to order it thru miller tools or find it on ebay.
Old Oct 15, 2012 | 05:59 PM
rehayes's Avatar
rehayes
Thanks I'll look that up.
