Neutral Safety Switch
Old Apr 15, 2014 | 05:28 PM
jennylynn35's Avatar
jennylynn35
Default neutral safety switch
New owner to a 98' Durango. Is it common for the engine to die if the neutral safety switch is what is needed to be replaced? Or could this be another issue? It has done it twice and both times, Thankfully, I was going slow and able to put the vehicle in neutral to start it and it worked fine.
Old Apr 15, 2014 | 08:46 PM
Old_School's Avatar
Old_School
The purpose of the NSS is to allow the truck only to start in neutral or park. It would not cause the engine to die but, if bad will cause the computer to throw a code telling you that it cant sense neutral ( dont know the code off hand). The engine stalling is another issue.
Old Apr 16, 2014 | 09:00 AM
jennylynn35
Thank you for responding
Old Apr 16, 2014 | 10:15 AM
hydrashocker's Avatar
hydrashocker
Your issue should be fuel or spark related. I would check fuel pressure on the fuel rail access point and ensure you have a good 50 psi throughout idle and the RPM range. Could be a bad coil wire as well if you haven't done a tune up check into my DIY sticky.
Old Apr 16, 2014 | 10:31 AM
that_guy's Avatar
that_guy
What exactly is going on when it stalls? Are you accelerating, coasting, maintaining constant speed? Does it sputter and die or just shut off?
Old Apr 17, 2014 | 02:34 PM
jennylynn35
Post
@ hydrashocker, I will be sure to check in to that, I was thinking possibly the idle air control motor but I will check the fuel pressure on the fuel rail access point before purchasing any parts. Thanks for the heads up.
@ that guy, when the rpms get down below a thousand and I am either decelerating with the break or coasting and it doesn’t do it all the time, however it is doing it more often now. The engine doesn’t sputter it just shuts off. I put it in to park and turn it over but nothing. I put it in neutral and it does start. This is why I was thinking it was a throttle body sensor or an air intake/ regulation issue. By no means am I a mechanic, just researching for clues to this puzzle and getting to know the Durango with all it quirks J
Old Apr 17, 2014 | 04:22 PM
that_guy's Avatar
that_guy
Try giving the battery connections a good cleaning (take off the cables and clean the posts and terminals). If the battery is weak or has weak connections it can screw with the computer and potentially keep it from idling right.
Old Apr 17, 2014 | 05:08 PM
jennylynn35
Thanks, I will
Old Apr 2, 2021 | 01:33 AM
Nika420's Avatar
Nika420
Originally Posted by twinrider1
About that 1"; socket....any issue getting it on? The only 1" deep socket I could find locally was a 1" drive from Auto Zone, and I just can't seem to get it on there. Not sure if it's the wall thickness or that there's a pretty pronounced ramp in the 'muzzle' before the socket portion begin. Before I take a grinder to this thing, does it require a thin-wall socket? Thanks.
So I'm sure you already made your move 8 years ago but I struggle with this little bastard. Your approach angle should be over the fluid line looking at it from the side of the vehicle you get a much better line of site. Of course after I got the bottom half of the sensor out....like I said I struggled....I noticed that perfect line of site for the damn thing.
