viscous fan removal
Old Oct 22, 2012 | 06:48 PM
raleigh5's Avatar
raleigh5
Default viscous fan removal
is there a way of removing the 1 mounting nut without destroying anything other than using the special tool( costs too much for my budget )? need to keep the pulley from spinning when the nut is rotated.
5.9L 1998 durango
Old Oct 22, 2012 | 07:02 PM
lvphotos's Avatar
lvphotos
http://www.oreillyauto.com/site/c/de...0764&ppt=C0173
I used the long needle nose 90 degree pliers. Cut the tips down enough to get into place and a firm hold up against the water pump and a 10-15" Cresant wrench. A 10 will work if you can get the mouth open enough. Open all the way if not far enough file down the screw at its termination to get it to turn a bit more.
Old Oct 22, 2012 | 07:22 PM
raleigh5's Avatar
raleigh5
thank you. i am borrowing the damper puller from oreilly's, so i can pick these up at the same time. very ingenious.
Old Oct 22, 2012 | 10:32 PM
rjlane1@pacbell.net's Avatar
rjlane1@pacbell.net
My experience with it.
Old Oct 22, 2012 | 11:39 PM
lvphotos's Avatar
lvphotos
There is a lot different under your Hood than my 1998 318. They have a strap wrench, not so aggressive, along with the pliers in the pulley. I work with turbines and a strap and a "Texas hot Rod " are in the gangbox! That's a torch to heat a big stud to break a nut!!!
Old Oct 23, 2012 | 12:05 AM
that_guy's Avatar
that_guy
yeah, if your pulley has holes in it you should be alright, but if yours doesn't like mine, you'll need to use a strap-wrench of some sort; either an real one like rjlane used in his video, or a makeshift one from an old serpentine belt like I usually do.
Old Oct 23, 2012 | 12:16 AM
rjlane1@pacbell.net
One other thing. I loaded it up with PB Blaster before I actually got the nut to break. I'm not sure how much it helped, but I was hammering the wrench and breaking my homeade tools before I got the chain strap wrench. The thing that was nice about the strap wrench is that you can do it alone once you get go wedged against the other pulley. My wrench was $10.
Old Oct 23, 2012 | 09:36 PM
raleigh5's Avatar
raleigh5
thanks for all the info. ended up using a $10 chain wrench from harbour freight and it worked very well...the video helped a lot and i thank you again.
