4wd issues that stumped the Dealer
Here's one for you Durango Pros! 03 Durango 4.7 1st gen.
Replaced engine (and tone rings) to 4.7 03 Dakota. No problem.
4wd didn't work. Switch tested, power to it, replaced TCCM (tried 4 different ones incase those were bad too) so TCCM ok, new motor for transfer case installed. We can turn it on with the computer but not in the truck itself.
Called dealer..says TCCM is bad. We've tried 4! Well,then I don't know.
Any suggestions from the peanut gallery?
So the switch has power and its good, the wiring from there to the motor is good and the motor itself is good? Have you checked the wiring at the motor with everything hooked up to see if it has voltage? If there's power at the harness and the motor works outside of the truck idk why it wouldn't work installed
Posted from Dodgeforum.com App for Android
Trending Topics
All the wiring was tested with a multi-meter. The 4wd can be engaged with the lotus (the hand held scanner) while it's installed in the truck but will not switch on manually. We've tried four different TCCM's and they all do the same thing. I'm trying to find someone who rebuilds TCCMs if that is even possible.
