shackles
Old Oct 26, 2012 | 01:53 PM
01dango4x4's Avatar
01dango4x4
Default shackles
Is there any way i can convince someone to measure their shackles for me? I plan on fabbing my own up at work and i would like to know the height of them so i know what to make mine to be the right lift.
Old Oct 26, 2012 | 05:13 PM
Old_School's Avatar
Old_School
Don't have any myself or i would measure them for ya... make sure to take pics and share the progress of how you made them if you can.
Old Oct 26, 2012 | 08:57 PM
01dango4x4's Avatar
01dango4x4
will do man. BTW i noticed a lack of information.. I'm looking for 3" lift shacklle dimensions. Any help would be very appreciated!!
Old Oct 26, 2012 | 09:05 PM
lvphotos's Avatar
lvphotos
Not to sound mean but take your stock length center to center and add 3". If your up to the task of building them yourself more power to ya, but all you need is a 3" drop/lift shackle for $50. Remember to add angle shims to readjust driveline angle.
Old Oct 26, 2012 | 11:23 PM
01dango4x4's Avatar
01dango4x4
Thats what i was thinking. I just wasn't sure if the angle of the shackle would cause the length to differ. I do fab work constantly at work and i do feel up to the challenge.
Side note what do you mean angle shims?
Old Oct 27, 2012 | 09:11 AM
lvphotos's Avatar
lvphotos
They are wedges in degrees to bring back driveline angle. They fit between axle and spring. You may or may not need them. Just check Driveshaft angle before and after. It will help with u -joint life. My axle is on the bottom of spring with the 6" lift.
Old Oct 27, 2012 | 09:16 AM
lvphotos's Avatar
lvphotos
If it was me a square tube and pipe combination for strength. Good luck and head over to Ride Of The Month and vote for me please.
Old Oct 27, 2012 | 11:27 AM
moabax's Avatar
moabax
Remember that with shackles you only increase the lift of the vehicle by half of the extra length in the shackle. For instance, you add 3 inches to your shackle, you only lift the vehicle 1.5 inches. This is because you are only extending one side of the spring.
Old Oct 27, 2012 | 04:59 PM
01dango4x4's Avatar
01dango4x4
That was my main concern with adding just the amount of lift i wanted. so if i want a 3" lift i need to add 6"
