Heated Mirrors
Old Dec 26, 2012 | 09:03 PM
wejones's Avatar
wejones
Default Heated Mirrors
I have a 99 SLT, 5.2, 256K and still getting 14.3 mpg, with heated mirrors that are cracked.
I read the following post:
https://dodgeforum.com/forum/1st-gen...hell-help.html
And I can't tell if his mirrors were heated after replacing the glass or not.
Is the heating element part of the glass or separate? Or can I just replace with a suitably sized mirror replacement and end up with heated mirrors.
Old Dec 26, 2012 | 09:38 PM
Old_School's Avatar
Old_School
The heating element is part of the glass ... Rockauto is the cheapest i found @ $23 bucks per side..
Note: the 6x9 Dumbo style mirrors where the only ones that come standard OEM with heat, They also make a non-heated Dumbo as i have learned. If you have anything else you would have to go aftermarket to get the heat added.. AFAIK there are no aftermarket glass pieces for the 5x 7 sport mirrors.
Old Dec 26, 2012 | 10:41 PM
wejones's Avatar
wejones
That works. Never used RockAuto.
Old Dec 27, 2012 | 09:58 AM
Old_School's Avatar
Old_School
Have had nothing but excellent service from them.
Old Jan 7, 2013 | 04:37 PM
IssaquahWA1979's Avatar
IssaquahWA1979
does anyone know if you got a Durango with the 5x7 mirrors if the wiring is in place for the heating element? I would just get a set of the dumbo mirrors with heat to change them to if the wiring is there as I like the bigger mirrors when towing
EDIT: My apologies I found the answer in a different thread when doing a re-phrased search... And to put the answer in this thread the answer is yes as long as you have the rear defroster.
Old Jan 7, 2013 | 08:23 PM
Old_School's Avatar
Old_School
That's only half true... the 98's DID NOT have the wiring as the heated mirrors where not offered till 99..
