1999 Durango 5.2. Dropped Crankshaft Position Sensor Gasket into engine. HELP.
Old Jan 6, 2013 | 06:22 PM
Navy_Engineer's Avatar
Navy_Engineer
Unhappy 1999 Durango 5.2. Dropped Crankshaft Position Sensor Gasket into engine. HELP.
Hey, I had the trouble "NO Bus" issue. I changed the PCM and 4 sensors because nothing seemed to be the problem. I have just tried swapping out the Crankshaft Position Sensor behind the block and as I was putting in the new one the gasket fell into the mount hole. I have been trying like hell for an hour to get it out with mechanical fingers to no avail. What can I do vice calling someone and paying out my ***?
Old Oct 18, 2013 | 09:15 PM
cmeads's Avatar
cmeads
It probably came out the bottom in the space betweenthe block and bellhousing. this just happened to me it came out when i tried to start it.
Anyone kno how to get that crank sensor back in with the rubber grommet? It seems impossible in that tiny area.
Old Oct 18, 2013 | 11:22 PM
that_guy's Avatar
that_guy
I don't remember there being any gasket or grommet on the crankshaft position sensor (assuming you're talking about the 5.2 or 5.9). Are you thinking of the camshaft sensor maybe?
Old Oct 21, 2013 | 01:01 PM
cmeads's Avatar
cmeads
No sir. i am talkin about the crank position sensor located between the block and bellhousing.accessible thru the passenger side wheel well. there is a rubber grommet that goes between the bell housing and the sensor. if you didnt have this grommet that may be a sign that its been previosly replaced.the cam sensor(sometimes called pick- up) you speak of is in the distributor. If i am not mistaken.
Old Oct 21, 2013 | 01:10 PM
dxloat's Avatar
dxloat
The only "no bus" issues I have ever seen were bad pcms or plug. You sure you don't have a bad pcm plug or pin?
Old Oct 21, 2013 | 02:19 PM
that_guy's Avatar
that_guy
I replaced my crankshaft position sensor a few years ago and there was no grommet on the old one or with the new one.
