What the heck does this go to?
Old Feb 6, 2013 | 03:31 PM
jacobhobbs08's Avatar
jacobhobbs08
Default What the heck does this go to?
A little background on the truck. '99 Durango 5.2 4x4. Just replaced the heater core and found this plug just hanging out by the a/c lines. Anyone have any ideas what it is? Its a 3 wire plug, wires are blue/green*maybe yellow*, white, blue/white. I'm kind of at a loss as to where it goes, so I figured I would come to you guys for help!
Also, not sure if this is related but the truck threw code P0171 after the heater core replacement....not sure if this plug thing is causing it or not.
Attached Thumbnails What the heck does this go to?-dscn1064.jpg   What the heck does this go to?-dscn1065.jpg
Old Feb 6, 2013 | 09:12 PM
go-part's Avatar
go-part
Former Vendor
http://engine-codes.com/p0171_dodge.html
If you could show a picture of the are that the wire branches off from, that would be a great help.
Old Feb 6, 2013 | 10:12 PM
otgarzà's Avatar
otgarzà
Sounds like a pressure switch pigtail/harness. Not sure if the 5.2 has that.
Old Feb 7, 2013 | 12:01 AM
jacobhobbs08
Branches from the pass. side main harness just above the washer fluid tank. Guess I should mention that the harness broke the pigtail off of whatever sensor it connects to.
Old Feb 9, 2013 | 01:26 AM
jacobhobbs08
Nobody?
Old Feb 9, 2013 | 08:21 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you have to wait for someone w/ a 5.x to chime in and tell you what it connects to, i dont have access to one to go out and check for you
Old Feb 9, 2013 | 01:26 PM
that_guy's Avatar
that_guy
Mine has 2 wires coming out of the main loom there. One goes to the a/c line and the other goes to a connector that then goes into the firewall there with the ac lines.
Old Feb 10, 2013 | 12:21 PM
jacobhobbs08
Bonus! Thanks for the pic. That answers my queston.
