Awd?
Old 02-26-2013 | 10:28 PM
SyntheticBlinkerFluid's Avatar
Default Awd?
I've been following the Snowdigger website, and his 2003 Durango has AWD. I had no idea the Durango came with AWD.
Is it possible to swap out a regular 4WD transfer case with an AWD one? Or is there more too it?
Old 02-26-2013 | 10:47 PM
Kensai's Avatar
Kensai
Only the R/T and possibly some SLT+ models have them.
Old 02-27-2013 | 08:44 AM
that_guy's Avatar
that_guy
If you can find an awd transfer case that will bolt up to your transmission it should be a direct swap. Since you have the electronically shifted case you'll need the appropriate selector switch, and if I remember correctly the control module you already have should work.
