evaporative/emmissions code P0440
Old Mar 4, 2013 | 10:21 AM
lilbittexas's Avatar
lilbittexas
Unhappy
All I can find by the battery is the purge valve solenoid and I just put new one in Friday. No cracks around green screw cap either. But I do smell fuel under hood when starting. Should I start looking at fuel lines?
Old Mar 4, 2013 | 10:26 AM
lilbittexas
The cylinder shaped black plastic piece is the purge valve solenoid and I have changed it already. I will look for the PCV valve, is there a way to check it or just have to replace.
I haven't had this truck a year and it has been nothing but problems from the start. It is the proverbial "money pit"!!
Old Mar 4, 2013 | 10:35 AM
SmokinJoe02's Avatar
SmokinJoe02
The PCV Valve is about $7 at Dodge. I'd just replace it.
SJ02
Old Mar 4, 2013 | 10:51 AM
lilbittexas
Ok ,found the filter.
Should I have some sort of vacuum going on at cannister? I disconnected hoses to and from cannisterwhile truck was running and absolutely nothing happened, no suction or blowing going on of any kind. Clogged cannister?
Old Mar 4, 2013 | 11:16 AM
SmokinJoe02
The cannister under the truck where the horseshoe shaped hoses are? That just holds some charcoal type stuff, I think. I believe it should all be free-flowing, so you should be good there. The PCV Valve has ball in it and should click freely when shaken. That is on the oil fill tube, under the hood.
SJ02
Old Mar 4, 2013 | 11:25 AM
lilbittexas
hoses/lines are in good shape. replaced purge valve, gas cap.
I disconnected hoses to and from cannister while truck was running and nothing happened and no vacuum or blowing going on anywhere, no change in idle.
Old Mar 8, 2013 | 12:04 PM
lilbittexas
Question why only 1 code
Why am I getting just the P0440 code with no accompanying codes. I have checked all lines/hoses, replaced gas cap, purge valve solenoid.
Old Mar 8, 2013 | 05:57 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
P0440 Evap Sys Per
you havnt been over all the hoses, they go everywhere and crack in the hardest to see places, what about the ones that go under the battery? yup part of the sytem
