Rebuild / Head Gasket Fitment - 318
1998 Durango slt V8 5.2 / 318. 4 speed automatic w/od /4X4
My question is. Where the orange tags are look at pic. The gasket does not have ports for the cooling channel. I have looked at other gaskets and they are all the same. This is a Fel-Pro Sealed power Pro Engine set. Iam wanting to know does this affect the cooling or can i open the ports up on the gasket or is there a reason for this. Can anyone help me out.
Iam wanting the best cooling i can get and this looks like its going to prevent cooling or cause hot spots
Yes, there are correct for there location and no i all ready trashed the olds ones. but i did check alot of diffrent makers and there all the same punch out. I wondering if i open the ports back up would this help the engine cool better of will it cause over heating
I know you may have done this already, But i thought i would ask anyway. Did you check out factory head gaskets? Because if they are the same as what you have.Then i wouldn't punch out any holes.
