My 98 5.2 will not crank and im going insane....help
Old Apr 9, 2013 | 07:37 PM
Boblobos's Avatar
Boblobos
Default My 98 5.2 will not crank and im going insane....help
Hi
I have a good bit of experience with dodges but i just cant figure this out ive replaced the starter the battery the cables and the relays and the fuses are good when i crank on the key i get a click out of the relays in both the fuse boxes and i checked the neutral saftey switch and that is functional...i dont know what else to check it was sitting a week before i noticed this because i was replacing all of the brake lines and wouldnt crank when i was done......any ideas.....thanks
Old Apr 9, 2013 | 08:47 PM
that_guy's Avatar
that_guy
try connecting 12v to the starter solenoid wire and see if it tries to spin, that'll rule out the starter at least.
Old Apr 9, 2013 | 10:24 PM
master tech's Avatar
master tech
Site Moderator & Tech
Does the engine spin if you turn it over by hand? I have had a frozen a/c compressor that wouldn't allow the engine to turn over.
Old Apr 10, 2013 | 12:15 AM
Boblobos's Avatar
Boblobos
I have jumped the starter and it starts but not with the key
Old Apr 10, 2013 | 12:44 AM
master tech
Maybe the ignition switch. If you put the transmission in reverse, does the back up lights come on?
Old Apr 10, 2013 | 08:52 AM
Boblobos's Avatar
Boblobos
I always had a problem with the the reverse lights they stay on all the time it will eventually blow the fuse i tested the ign switch and it works fine i jymped the starter from post to post and it starts i just dont have power at that brown wire and i traced it back to the firewall thinking it might of been a bad wire but it was good
Old Apr 12, 2013 | 04:12 PM
rjtx667's Avatar
rjtx667
what happens if you put the transmission in neutral then try to start it?
Old Apr 13, 2013 | 01:35 PM
Boblobos's Avatar
Boblobos
Nothing
Old Apr 14, 2013 | 12:57 AM
master tech
Have you replaced the safety neutral switch?
Old Apr 14, 2013 | 09:29 AM
Old_School's Avatar
Old_School
I had the same issue a few years ago... if i tried to start it with the key nothing but it i crossed the terminals with a screwdriver it fire right up.
After a month in a half of pulling my hair out i traced the issue back to the relay in the PDC. the relay itself was fine, but the clips that make contact with the relay where loose and when i put the relay back into the cavity they where getting pushed out and not making contact with the relay..
Took the PDC apart and made sure all the clips for the starter relay where pushed up and seated on the relay. Put everything back together and turn the key and Vola! it started!
HTH
