2000 Dodge rear wiper, issues
Old Apr 22, 2013 | 01:05 PM
bradcw557289's Avatar
bradcw557289
Default 2000 Dodge rear wiper, issues
The rear wiper on my Durango only works when the washer button is pressed. I checked the fuses, replaced the switch and still, when I turn the wiper on, it doesn't work without the washer on. Any suggestions?
Old Apr 22, 2013 | 01:40 PM
arcticpower28's Avatar
arcticpower28
Gf has somewhat of the same issue, it is smetimes hard to start when the window is wet or dry sometimes you have to go help it get started and then its good. when its wet it will keep going once started, No lube on the window it will stop as soon as you take your hand off of it from helping!
Old Apr 23, 2013 | 03:03 PM
bradcw557289
My wiper works just fine, the motor is strong, the issue is that it won't wipe the window unless it is washing the window.
Old Apr 23, 2013 | 03:06 PM
xbxjunkie's Avatar
xbxjunkie
check your ground in the hatch, mine did the same thing
Old Apr 23, 2013 | 04:27 PM
that_guy's Avatar
that_guy
yeah, that sounds like a wiring issue
