tranny problem please help
Old May 28, 2013 | 07:56 AM
rican's Avatar
rican
Default tranny problem please help
hello need some help my 5.9 r/t is giving me tranny problems first it feels like its stuck on a high gear but i would play with the 4x4 shifter and the other shifter it would shift just fine but after a couple a days it would get stuck on high gear again also when stuck on high gear when im goin to take off it makes a whinning noise then the noise goes away till i have to take off again when it does happen the check engine light goes on and when shifting good the light goes off
Old May 29, 2013 | 11:20 PM
master tech's Avatar
master tech
Site Moderator & Tech
Do you know what the codes are for the check engine light? I'm guessing the governor solenoid is sticking and causing you to start off in a high gear. The whining sound maybe a planetary gear set and if you don't have the transmission looked at soon. You maybe replacing it.
Old Jun 3, 2013 | 06:39 AM
rican's Avatar
rican
the code is 0753 solenoid persure read somewhere tha if would switch he relay it would fix th promblem soi did try that and s far its working fine but if it does do it to change filter an d pan and change solenoids
Old Jun 5, 2013 | 09:52 PM
master tech
Send me your email address and I'll send you the pdf file for that and some other transmission codes.
Old Jun 6, 2013 | 09:10 AM
rican's Avatar
rican
my email is rican197336@yahoo.com thanks for the help been breaking my head with this
