Pulling a car on a trailer?
Old Jun 23, 2013 | 11:27 PM
Durango03's Avatar
Durango03
Question Pulling a car on a trailer?
I've got an '03 Durango 4.7. Wondering if its ok to pull a trailer with it? I don't have the tow package (as far as I know), but I have a class III hitch that I put on it with the 4 pin light kit. I'm planning on driving it 6-7 hours north to PA from NC to take my Mustang to Carlisle next June. If not than I'm gonna have to rent a truck AND a trailer. Thanks for the info!
Old Jun 24, 2013 | 02:00 AM
adukart's Avatar
adukart
What gears do you have (then you can look at the chart in the diy section)? You should be fine with that small of a load.
Old Jun 26, 2013 | 10:21 PM
Durango03's Avatar
Durango03
I'm not sure what gears I have. IIRC, isn't there a sticker in the glove box that has what gears are in it?
I was concerned with not having a tranny cooler and not having HD rear shocks. I'm going to try and find some mirror extenders also. Not sure what else I will need or what else I should be concerned with.
Old Jun 26, 2013 | 11:03 PM
adukart's Avatar
adukart
Yeah there should be a sticker in the glove box. HD shocks aren't needed it just makes sway less of an issue when towing in a wind with a not so smooth road. The ride height is determined by the leaf springs.
Old Jun 27, 2013 | 03:31 PM
AppelH's Avatar
AppelH
If you had to put a hitch on yourself, then it probably isn't set up for towing from the factory, which means no tranny cooler and 3.55 gearing, but I may be wrong. If this is the case, a car on a trailer will probably be close or over the tow rating for it. Does this trip have a lot of hills? If so it's going to working to maintain speed
Old Jun 27, 2013 | 05:56 PM
Old_School's Avatar
Old_School
Mine came with 3.92 gearing and no tow package.
Old Jun 27, 2013 | 08:19 PM
AppelH's Avatar
AppelH
Wouldn't be the first time I have been wrong. I think I just assumed that anyways, don't know if I actually saw it anywhere
Old Jun 27, 2013 | 08:22 PM
AppelH's Avatar
AppelH
Also, if you can't find a tag in the glove box, there might be one on the rear axle. I just found the tag earlier when I was under there checking something.
Old Jun 27, 2013 | 09:32 PM
Old_School's Avatar
Old_School
Yeah there SHOULD be a tag that says either 3.5 or 3.9, with 3.5= 3.55 and 3.9= 3.92 obviously.....
Old Jun 28, 2013 | 05:46 PM
Durango03's Avatar
Durango03
Just looked. Sticker says 3.55 gears. As for hills, I've never been there so I'm not sure.
So I'm guessing that it will be too much for my Durango? Sux, cause now I have to debate on renting a truck AND trailer or just a trailer and borrow a truck.
I've got 185,000 miles on her now, I don't want to overwork it and break something.
