Aftermarket headlights and fast blinkers
Old Jul 21, 2013 | 09:03 AM
Gschutts's Avatar
Gschutts
Default Aftermarket headlights and fast blinkers
Hello - 2000 Durango --swapped out the stock headlights with some Spyder projector type . Since the new lights don't have 2 turn signal lamps now the turn signals blink double time. Can you help me with a solution? I did connect some LED's to the second turn signal connection but still have the fast blink. Must be a resistance issue but not sure how to resolve.
Thanks for the help.
Old Jul 21, 2013 | 10:29 AM
that_guy's Avatar
that_guy
You have 3 different options here.
1) Leave a regular bulb in the unused socket. The bulb in the headlights needs to be a regular too if this is the way you want to go.
2) Get load resistors that simulate having a regular bulb. This will require a bit of wiring.
3) Get a heavy duty flasher module. They're about $16 at your local auto parts store.
Old Jul 21, 2013 | 11:00 AM
Gschutts's Avatar
Gschutts
Can you tell me where the flasher module is located?
Old Jul 21, 2013 | 11:01 AM
that_guy's Avatar
that_guy
Up under the dash on the drivers side. The factory one should be green.
