crank sensor
Old 07-23-2013, 10:17 PM
cfisher9889's Avatar
cfisher9889
cfisher9889 is offline
Default crank sensor
i just pulled the tranny out to replace the front seal on a 2000 durango and didnt know about the ckp sensor and bent the flywheel/drive plate i bent it all back but now i cant get it to run right i have replaced the ckp, pickup coil, and the cap and button and still no luck was wondering if the flywheel/drive plate is the problem
Old 07-23-2013, 11:00 PM
that_guy's Avatar
that_guy
that_guy is offline
All the little holes in the edge of it are what the sensor picks up, so if you messed those up it could be the problem.
Old 07-25-2013, 04:50 PM
cfisher9889
thanks i got it figured out they are very sensitive i had some burrs on it filed them all down now it runs better than ever
Quick Reply: crank sensor
