brake lights wont brighten
Old Jan 5, 2010 | 08:59 PM
ronisi's Avatar
ronisi
Default brake lights wont brighten
hi i'm new here i have a 2002 dodge durango r/t and the brake lights won't brighten when pressed the bulbs are not burnt out because the daylight running lights are working also the third (top) brake lights up when pressed.thanks for any help
Old Jan 5, 2010 | 09:29 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
sounds to me like the brake light filament in the bulbs is burnt out, either that or a fuse,
btw the bulbs have multiple filaments in them so one can burn out without the other ones going, try new bulbs, its a cheap thing to try
Old Jan 6, 2010 | 09:09 AM
Duranged408's Avatar
Duranged408
what he said
Old Jan 6, 2010 | 09:13 AM
Dans01Durango's Avatar
Dans01Durango
What they^^ said.
Old Aug 15, 2011 | 08:05 PM
Tunnelmen's Avatar
Tunnelmen
I have the exact same problem...cant seem to find bad fuse, replaced bulbs...Any resolution?
Old Jan 8, 2012 | 10:41 AM
harleytech's Avatar
harleytech
Brake Switch...?
Old Jan 8, 2012 | 12:05 PM
otgarzā's Avatar
otgarzā
Another thing...if you take the socket out there is the silver pins or basically the grounds on the both socket and bulb housing. Look to see that one of those ends isnt melting into the housing or socket. If it is just take it out with a thin knife or scraper.
Old Jan 8, 2012 | 01:58 PM
greasydriveway's Avatar
greasydriveway
+1. I fixed mine by laying a little piece of old wire on the contact point. Just to help make sure everything touches. A dab of solder might work too.
Old Jan 9, 2012 | 11:47 AM
otgarzā's Avatar
otgarzā
Same here. Became a headache since i got all new bulbs then bought a socket and i was ready to get a new housing then someone told me about those contact points and there it was...burning into my housing. Just popped it out and it fixed my problem.
Old Jan 9, 2012 | 07:25 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would also check your ground circuit too, as well as what the other members recommend.
