Window issue
Old Jul 29, 2013 | 03:14 PM
topgunram's Avatar
topgunram
Default Window issue
So the drivers side window just slides up and down. I can hear the motor working a little bit but it doesn't move the window any.
Old Jul 29, 2013 | 09:27 PM
that_guy's Avatar
that_guy
Sounds like the window probably came off it's carrier or something along those lines. You'll have to take off the door panel to see whats going on for sure though.
Old Aug 3, 2013 | 04:40 PM
topgunram's Avatar
topgunram
Took the door panel off. As far as I can tell the window is still on the track. There is a steel cable that seems to be connected to the motor and the window just seems to be flopping around loose
Old Aug 3, 2013 | 05:36 PM
tooltime's Avatar
tooltime
Our Durango passfront window would not go up this week. The cble was hanging there and motor makes noise. I just got a used regulator today and will put on tomorrow
Old Aug 5, 2013 | 12:00 PM
Kensai's Avatar
Kensai
Depending on the price of a used regular at a pick and pull, I would just opt for a new replacement that is anywhere from $50-$80 for a complete assembly. They usually come with a 1 year warranty or longer when buying new.
The cable is held in place by a cheapy plastic part that will break over time. So getting a used one from a pick and pull, you just don't know how long it will last and will cause you more time to tear down your door a 2nd time to replace it again.
