2001 Durango propeller shaft ?'s
on a 2001 Durango propeller shaft, is there supposed to be a rubber boot to cover the bearings? On the end that connects to the transfer case, I can look in there and see all the bearings, I looked on advanced auto and they sell a drive shaft propeller assembly kit and it has a boot and rubber where the drive shaft fits in. So should there be rubber around the part? I can also move the end that goes on the transfer case maybe 1/4 inch or so and when you put it in 4wd it has a grinding noise
What do you mean propeller shaft?
The drive shaft that connects the transfer case to the front CV axles??
I have my durango sitting infront of me right now so I can look before it gets too dark..
(posted this picture a minute ago so I already had it copied haha)
http://www.flickr.com/photos/92140865@N03/10217349114/]IMG_8708[/url, on Flickr
yes it comes from the transfer case to the front diff. The side that is connected to the transfer case, I can look at it and see the bearings inside sitting around what looks like a boat propeller, Im wanting to know if there is supposed to be a rubber boot or something there, also should I be able to move it up and down, side to side?
