AWD T-case fluid
Old Oct 26, 2013 | 06:30 PM
AppelH's Avatar
AppelH
Default AWD T-case fluid
Does the fulltime 4wd transfer case use a special oil? My rig didn't come with a book, and I misplaced my service manual. Also does the front differential use something other than 75w-90 gear oil?
Old Oct 26, 2013 | 08:18 PM
JeeperDon's Avatar
JeeperDon
Atf +4 for the t-case. I just used regular viscosity range gear oil in the axles.
Old Oct 26, 2013 | 08:33 PM
AppelH's Avatar
AppelH
I was hoping that was it, have some left over from tranny service
Old Oct 26, 2013 | 10:41 PM
JeeperDon's Avatar
JeeperDon
Remember to use LSD type gear oil of you have LSD. I used that in both ends of my R/T.
Old Oct 26, 2013 | 11:12 PM
AppelH's Avatar
AppelH
Crap I'm glad you said something..all this time I hadn't thought about it because I didnt think i had one, then you said something and I went and checked my buildsheet...
DRBP Corporate 9.25 LD Rear Axle
DSA Anti-Spin Differential Rear Axle
Now I have to remember what kind of oil I put in it. If I didn't have the additive, would I have a noticeable chatter or anything?
Old Oct 27, 2013 | 09:45 AM
JeeperDon's Avatar
JeeperDon
No adding special stuff needed these days. There are many brands of ready to go LSD quarts of gear oil.
Old Oct 27, 2013 | 10:15 AM
that_guy's Avatar
that_guy
True, but if he forgot to get the oil with the friction modifier already in it, he can just add it to the oil.
Old Oct 27, 2013 | 11:39 AM
AppelH's Avatar
AppelH
Wonder if I should put a bit in just to be on the safe side. Shouldn't hurt anything to have some extra right?
Old Oct 27, 2013 | 11:57 AM
JeeperDon's Avatar
JeeperDon
I didn't, and am not worried at all.
Old Oct 27, 2013 | 12:12 PM
AppelH's Avatar
AppelH
The problem is I have no idea what kind of fluid I put in. Chances are I was too cheap to get a decent oil.
On a side note, do all of the r/t models come with awd?
