Still running cold
Old Nov 22, 2013 | 09:04 PM
that_guy's Avatar
that_guy
That sounds like it might be your issue. Honestly all of the aftermarket ones I've come across are completely $hit, just get the mopar one from the dealer.
Old Nov 22, 2013 | 09:06 PM
AppelH's Avatar
AppelH
I should clarify i replaced it last spring, so it hasn't been run in the cold until now
Old Nov 22, 2013 | 09:07 PM
that_guy's Avatar
that_guy
Well why don't you take the fan off and see if it warms up to temp (just be sure not to let it overheat without the fan on it). If it does you know what your problem is.
Old Nov 22, 2013 | 09:09 PM
AppelH's Avatar
AppelH
Hopefully. My dad is hopefully bringing up the tool with him to get it off this week. We will see. Does anyone know if a bad coolant temp sensor could be causing issues? Is this the sensor that the gauge reads from?
Old Nov 22, 2013 | 09:10 PM
adukart's Avatar
adukart
Yeah I got a normal duty one from napa but the mopar one has the best reliability rating that I've seen. It should shut off within a mile or so when its this cold. I don't see the need for a HD clutch. I've towed in 100 temps with cardboard (long story, I didn't know it was there) and it never went above 215 according to the gauge.
that_guy's Avatar
that_guy
The coolant sensor certainly wouldn't keep the engine from getting up to temp if that's what you're asking.
Old Nov 22, 2013 | 09:11 PM
AppelH's Avatar
AppelH
For some reason I think I checked awhile ago, and you can't get just the fan off without the clutch. And I don't have te stuff to get te clutch off
that_guy's Avatar
that_guy
I got so fed up with trying to deal with the clutches that I just went ahead and replaced the mechanical fan with an electric one with even more air flow for less than the mopar clutch.
Old Nov 22, 2013 | 09:12 PM
AppelH's Avatar
AppelH
Yea the hd one is all I could find, I never thought to go I a dealer since generally there stuff is about twice as expensive
Old Nov 22, 2013 | 09:13 PM
adukart's Avatar
adukart
No a bad temp sensor will cannot cause the motor to not warm up only give a bad reading. All the coolant is controlled by mechanical devices that respond to the motor/coolant temp directly. You guys type to fast lol, just realized this has been addressed.
