Still running cold
Old Nov 22, 2013 | 09:14 PM
  #21
AppelH's Avatar
AppelH
Yea I would really like to go to an electric fan set up actually.
  #22
that_guy's Avatar
that_guy
Originally Posted by AppelH
For some reason I think I checked awhile ago, and you can't get just the fan off without the clutch. And I don't have te stuff to get te clutch off
I don't believe you can get it off without the clutch being taken off.
I know they changed the radiator setup slightly for 2000, but I never used any special tool to take mine off. I just used an old serpentine belt to hold the waterpump pulley and a big *** crescent wrench to break the nut loose.
Old Nov 22, 2013 | 09:17 PM
  #23
AppelH's Avatar
AppelH
Well if the temp sensor is reading wrong, and my motor actually is at temp, then the low heater output could be addressed elsewhere. I will take the clutch off and go from there.
I'm typing on my phone and its annoying, this forum isn't phone friendly lol
Old Nov 22, 2013 | 09:18 PM
  #24
AppelH's Avatar
AppelH
I dont think my crescent was big enough, it's only medium a$$ sized. And I'm too cheap to buy a bigger one, I can wait a few days
  #25
that_guy's Avatar
that_guy
There is an app and a mobile version of the site.
Old Nov 22, 2013 | 09:23 PM
  #26
adukart's Avatar
adukart
Get the right sized wrench and hit it with a rubber mallet while having someone put tension on the belt using a wrench on the tensioner. or if you have access to an air hammer, thats how the tech's do it a the dealership I work at.
Old Nov 27, 2013 | 04:18 PM
  #27
AppelH's Avatar
AppelH
Was able to flush out my heater core today. I didn't seem to get much crap out of it, but it helped my heater considerably. I still feel like my engine temp isn't as high as it should be, but as long a so have heat I don't care.
Old Nov 27, 2013 | 10:27 PM
  #28
adukart's Avatar
adukart
You should care. Improper temperature is hard on head gaskets.
Old Nov 27, 2013 | 11:16 PM
  #29
AppelH's Avatar
AppelH
I should rephrase that. I thought my low temp was causing my heater issues, turns out it wasn't, therefore it might not be running as cold as I think. IF it is stilll running cold, I don't know where to look next. I removed te clutch fan like i planned, that made no difference.
Old Nov 28, 2013 | 10:18 AM
  #30
adukart's Avatar
adukart
Ok, do you have the numbered gauge or the H and C gauge?
