Heater problem
Old Nov 23, 2013 | 10:34 AM
budah93's Avatar
budah93
Default Heater problem
I have a 99 durango and my heat has decided to not work properly. If it's above 40-45 degrees it comes out warm, any colder than that i got mildy warm air unless I turn it to my windshield vent and it comes out decently warm but no where enough to warm the vehicle up. I just changed the thermostat and topped off my antifreeze and it didn't change anything. You guys have any help? It's supposed to be in the single digits next week so i need to get it fixed. Thanks!
Old Nov 23, 2013 | 10:45 AM
Old_School's Avatar
Old_School
i would look at a partly clogged heater core. Try flushing it out and see if that help.. here is a video on some ways to do it ~~>
Old Nov 27, 2013 | 04:15 PM
AppelH's Avatar
AppelH
Agreed. I did mine literally about 20 minutes ago, and it blows much warmer now
Old Nov 29, 2013 | 12:33 AM
master tech's Avatar
master tech
Site Moderator & Tech
Also check the AUX coolant valve on the right side frame rail too.
Old Nov 29, 2013 | 10:39 AM
AppelH's Avatar
AppelH
Whats the deal with this? What does it do?
Old Nov 30, 2013 | 11:34 PM
master tech
The correct name is a auxiliary coolant pump. Mopar number 55056055AA. The pump helps with coolant flow to the heater core.
