Removing deformed grille screw
Old Nov 25, 2013 | 08:44 PM
Howardeer's Avatar
Howardeer
Default Removing deformed grille screw
Hello,
There is a cross slot/phillips screw that holds my grille and I just can't remove it. I tried to take it out with a screwdriver a while ago and all that did was deform the head. Now the screw head is basically a giant hole in the center. Should I apply WD 40 to remove it? Thx in advance
Old Nov 25, 2013 | 10:03 PM
that_guy's Avatar
that_guy
I'd use a dermal with a cutting disc on it to try and make a slot that you could get a flat blade screwdriver in.
Old Nov 26, 2013 | 06:10 PM
moe7404's Avatar
moe7404
an automatic center punch can be used as a small impact wrench. use the sharp point to dig in to the screw with the punch at an angle, can turn the screw. its not fast but if it moves at all you are on your way.
Old Nov 26, 2013 | 06:16 PM
dolittle's Avatar
dolittle
Alden 8530P Grabit Damaged Screw Remover 3 Piece Kit - Amazon.com Alden 8530P Grabit Damaged Screw Remover 3 Piece Kit - Amazon.com
I have had good luck with this tool.
