Lights?
Old Nov 27, 2013 | 11:32 AM
cowboyup1378.mr's Avatar
cowboyup1378.mr
Question Lights?
I have a 1999 Durango and my 4x4 light does not come on when I engage the 4x4, and my dash lights and running lights come on when I hit the brake... any ideas?
Old Nov 27, 2013 | 11:44 AM
Old_School's Avatar
Old_School
There is a short somewhere causing it... sadly you are headed into a electrical nightmare... i would start by tracing wires under the truck looking for any that are chewed up or burned... you could also unplug the sensor on the transfer case and see if it being bad is causing the short.
Old Nov 27, 2013 | 12:09 PM
dxloat's Avatar
dxloat
If that doesn't work....
Is it still shifting into 4x? If it is not then It could be the blue box(tccm) inside the dash. Mine went bad like you described, replaced it with a junkyard part for about $80. Expect scraped knuckles and a little cursing.
Old Nov 27, 2013 | 12:45 PM
that_guy's Avatar
that_guy
There's no tccm on the 98-00 trucks, it's all mechanical.
Since you say the parking lights come on when you hit the brakes, I'd check the tail lights first. Unplug them and see if the parking light problem goes away, if so you know where the problem is, if not you know where it isn't.
Old Nov 27, 2013 | 12:50 PM
dxloat's Avatar
dxloat
Oops, wasn't paying attention. Disregard my ramblings.
Old Dec 3, 2013 | 10:19 AM
cowboyup1378.mr
4x4 does work the light just doesn't come on. As for the other issue I'll have to heck out the wiring. Thank you
Old Dec 3, 2013 | 03:35 PM
Old_School's Avatar
Old_School
After reading this a few times and doing this ~~> the dumbass light inside my head came on and i thought, why didnt i ask if the bulb inside the cluster was bad?.. You can test all the lights by holding in the odom reset while you turn the key on this you see "chec" inside the odom window... it will cycle throw all the lights you just have to take notice as to if the 4x4 lights come on... might be as simple as a blown bulb or bulbs...
also check around the brake petal for any pinched wires.
Old Dec 3, 2013 | 06:11 PM
that_guy's Avatar
that_guy
I'm not entirely sure if that actually works for the 4wd indicator lights. I'm pretty sure they're hard wired so they won't fail if the rest of the instrument cluster does, at least that's how the FSM makes it seem.
Old Dec 3, 2013 | 08:21 PM
Old_School's Avatar
Old_School
I tested mine earlier and the 4x4 lights came on in the check..
Old Dec 3, 2013 | 08:45 PM
that_guy's Avatar
that_guy
Good to know.
