Polished turd?
Old Dec 22, 2013 | 05:51 PM
PublicHair's Avatar
PublicHair
Originally Posted by that_guy
All the aftermarket ones I've had are just too aggressive with their engagement, that's why I ended up going the all electric route.
Electric is the route to go for sure. It’s a noticeable difference for sure when I removed my fan clutch and just ran the OEM electric fan instead.
Old Dec 22, 2013 | 05:55 PM
that_guy's Avatar
that_guy
Yeah, I noticed a slight increase in mpgs and throttle response.
Old Dec 22, 2013 | 05:57 PM
PublicHair's Avatar
PublicHair
I didn’t notice any MPG gains but throttle response a noticeable difference. Tho not like it matters too much. I could (before AWD) still roast both tires from a dead stop
Old Dec 22, 2013 | 06:19 PM
Daves69's Avatar
Daves69
Maybe try a hair dryer or very low heat gun setting on that silly stuff to loosen up??
You might try contacting these folks.
From the MSDS......
CAR-FRESHNER Corporation
21205 Little Tree Drive
Watertown, NY 13601
(315) 788-6250
"Silly" site
Phone: (315) 788-3431
Fax: (315) 788-7467
Mail:
SILLY STRING Products
P.O. Box 719
Watertown, NY 13601
USA
Old Dec 23, 2013 | 10:51 AM
stupiid13's Avatar
stupiid13
Ok so i googled the sound that the fan clutch makes and its practically identical to the one my forest gump is making! Which makes me feel a hell of a lot better because i was worried it was going to be something BIG! As for the PS i need to clean the motor up so i can see where its leaking at, it dont really leak til the motor has been running and warmed up. Im so glad i found this forum and thank yall for helping.
Old Dec 23, 2013 | 02:59 PM
stupiid13's Avatar
stupiid13
another thing... i read up that you can remove the belt, crank the Durango and see if it still sounds like a vacuume if the noise stops you know that its the fan clutch. Has anybody tried this?
Old Dec 23, 2013 | 07:23 PM
that_guy's Avatar
that_guy
You can but don't run it for long because you'll have not coolant circulating.
Old Dec 23, 2013 | 11:51 PM
stupiid13's Avatar
stupiid13
thanks
