Heater core replaced now no lights and air bag light
Old Jan 9, 2014 | 07:54 PM
mainewoodshunter1's Avatar
mainewoodshunter1
Default Heater core replaced now no lights and air bag light
2000 dodge Durango 4.7 slt plus
Tried replacing heater core didn't end well for the heater housing. It was cold thing cracked apart. So I put everything together w/o the heater housing. So I believe I got all the connections and grounds I count 1 ground on each side and one in the middle for the airbag. I made sure to plug in the airbag harness into pita air bag thing in the middle.
So anyways my minds all over the place right now. So theres no head lights. I have brake lights turn signals a/c heat controls light up. But no headlights no dash lights no interior lights. And the air bag light wont shut off.... Please help.............
Old Jan 9, 2014 | 08:02 PM
mainewoodshunter1
Ive rebuilt engines and transmissions. Ive worked on trains trucks and farm equipment. Ive restored cars that no one thought was possible. Never again will I take apart this recycled plastic dash. What a pita of a design flaw. I think I will stick to older cars from now on.
Old Jan 9, 2014 | 08:18 PM
TravisN.'s Avatar
TravisN.
I don't have first hand experience, but reading through the manual, the only thing that makes sense is a connection got missed on install.
Old Jan 9, 2014 | 08:41 PM
mainewoodshunter1
I keep looking at the wiring diagrams and connections and grounds and I cant find anything.
Old Jan 9, 2014 | 08:44 PM
mainewoodshunter1
I noticed something else aswell my door locks don't work. However then alarm does arm.
Old Jan 9, 2014 | 08:49 PM
that_guy's Avatar
that_guy
Sound like your ctm isn't properly hooked up or grounded.
Old Jan 9, 2014 | 08:51 PM
mainewoodshunter1
Man I hope I didn't mess up the wireing harness or something.......
Old Jan 9, 2014 | 09:56 PM
mainewoodshunter1
In your door the fuse block is there two relays and two metal fuses then all the little ones? I only have one relay and one metal fuse theres two empty spaces....
Old Jan 9, 2014 | 10:02 PM
mainewoodshunter1
Nm Scratch that I looked it up its how its suppose to be.
Old Jan 9, 2014 | 10:54 PM
that_guy's Avatar
that_guy
double check all the connections to the ctm, the grounds, and the connectors up under the driver's side footwell.
