Determining Transmission and Transfer Case
I have heard that you can tell what kind of Transmission you have by using the VIN number?
Anyone know a website or how to read the VIN to determine this?
I tried the VIN decoder on this site ( https://dodgeforum.com/forum/vindecoder.php ) , but it did not give me what I was looking for.
I am curious to know what Transmission and Transfer Case my Durango has.
Figured this thread could help others as well, if there are answers to my questions.
Thanks in advance.
Thanks in advance.
Thanks for the info.
So are you saying the 03 has the 545rfe? (other years it was the 45rfe?)
I found a "Contact" page elsewhere on the forums, so I will post it in this thread for future reference.
http://www.dodge.com/webselfservice/...ull&category=U
Yeah, the 45rfe and 545rfe are completely identical. In 00-02 they were only programmed to use 4 gears sequentially with an extra 2nd gear for kickdown (who knows why), but in 03 they changed it to use all 5 sequentially still with the extra 2nd kickdown gear. So theoretically it could have 6 forward speeds (it did later in some Rams). A lot of people with 01-02 Durangos can swap out their TCM (transmission control module) with one from WJ Grand Cherokee, because they were programmed to use 5 gears like the 03 Durangos were (except the 03 Durangos have the TCM integrated to the PCM).
Here's some more info on the ratios in them: http://en.wikipedia.org/wiki/Chrysle...RFE_and_545RFE
You can also take your VIN to the dealer and they will print you off a build sheet... In the past i have found that most dealers would be happy to do it, in fact when i took mine they noticed that there was a recall that was never done and ask if i mind saying for a few mins so they could inspect it.
Got a reply from the e-mail I sent using the webpage link above.
Some helpful information I learned:
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter
DH6S AWD Single Speed Transfer Case
DJDS 205MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
EVA 4.7L V8 MPI Engine
