fuses keep blowing
Old Mar 1, 2014 | 09:24 PM
ousoonergirl05's Avatar
ousoonergirl05
Thumbs down fuses keep blowing
the other day I couldn't figure out why I had no tail lights dash lights or tag light but I figured that out and got the right fuse changed. anyways now it did it again. fuse is blown and put a new one in and it worked but now there is a burning plastic smell. what could this be? and it looks like its melting the fuse box in that spot. I don't know whats going on with this dang truck someone please help
Old Mar 1, 2014 | 10:50 PM
that_guy's Avatar
that_guy
Do you have a trailer harness plugged in by chance? On time water got in the plug of mine and kept shorting the fuse.
Old Mar 2, 2014 | 12:27 AM
PublicHair's Avatar
PublicHair
Or water in turn signal light or tail lights.
Old Mar 2, 2014 | 08:40 AM
ousoonergirl05
It smells like burning wires and its melting the fuse slot. No trailer. Could it be a stereo?
Old Mar 2, 2014 | 11:49 AM
that_guy's Avatar
that_guy
Not unless the stereo is on that circuit in the fuse box.
Old Mar 4, 2014 | 11:45 AM
hydrashocker's Avatar
hydrashocker
You have a short to ground most likely some water in one of your turn signals or brake lights.
If you have a tow package installed you have a female trailer plug on the rear of your truck. You can disconnect the female plug by looking behind it and there is a red lock you pull out then pull the harness off. See if the issue stops and if it does replace the female plug, you need to go to a dealership for the plug.
Old Mar 4, 2014 | 06:23 PM
MoparMan1991's Avatar
MoparMan1991
Happened to me when my trailer harness came in contact with the exhaust pipe, and melted through the wires.
